| Home > Help Needed / General Tech Chat > pistons | |||||||
173 Posts Member #: 873 Advanced Member Thatcham, berkshire |
29th Dec, 2006 at 06:42:44pm
in need of some new pistons am on tight budget atm due to various other funds needed. i came across slipper pistons and they seem really cheap for a set. y is this it says u can get 8.8 CR ones. my only guess is the piston is shirter but that would mean they wopuldnt be able to take the turbo. is that right. any help. just a long shot |
29th Dec, 2006 at 10:55:35pm
The 201251 pistons should be ok, the reason they have a lower compression is because they are 'shorter'. The crown of the piston sits lower in the block, if its a standard, unmachined block.
