Home > Help Needed / General Tech Chat > Clutches ... again ......
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Right, I have searched and searched and now have even less of a solid view than I did when I was asleep.
I am looking for the best combination of reliability (ie not slipping) Vs. lightest pedal (car is for a lady remember!!!) that is likely to hold with around a 120ish BHP engine ..... I know torque is the clutches limitiation but I am not sure what a 120 bhp ish lump will be giving peak torque wise as I haven't built it yet. If it was a motor for me I'd stick a Grey in and be done with it (with TD's backplate mod).
I guess the questions are;
1) will an orange do?
2) will machining the backplate (assume it will be adifferent amount) to put the spring level / parrallel also offer the best solution for clamping Vs. release load (should do I think ....)
Anybody got any experiences with the orange????
P.S. Sure I have mentioned this but she is coming from a modern charriot to a Mini and the car will be heavy ... lots of soundproofing, lecy window, central locking, ICE, back seats that will be used (even our dog is near 9 stone) and the car will get driven through town traffic as she works in a central branch of a bank. I fear for the clutch .... and the engine mounts, steady bars, subframe mounts .......... why did I let her talk me ino building this thing for her??????? *wink*
LOL
Sounds to me like you should consider the top of the range Verto clutch.
They are known to hold 100 lbft on top spec 1430 N/A engines according to Morspeed.
I'm using the minispares lightened verto flywheel with the AP clutch and plate for a similar output on my 998 turbo.
Not tested yet though.
RogerM
Member #: 1217
Axel .. thanks for the information. I was wondering about the best of the verto units.
The only concern I have with the verto set up is ifshe does decide to turn up the bost later on it will mean a complete new set-up. Also the way a turbo delivers it's power is very different to a NA unit. I am slightly concerned that the sudden torque increase as it comes on boost might unsettle the clutch if it's living on the edge.
With that in mind and the fact that I have a standard pre-verto set up sitting on the donor cars 850 engine I was going to use that with an uprated diaphram and plate purely due to the fact that it provides a route for easy upgrade.
Will be very interested in your results with this clutch though ...
If you already have the pre-verto setup, then it would be best to just uprate the cover.
The cost of conversion either way is a lot of cash, if you go the lightened route.
Mines going to be a daily drive with limited use on boost so I'm hoping the verto will be OK. I can always change it later!
RogerM
Member #: 1217
But the verto gives so much more engine bay space .... for the IC maybe (ducted air from the front of course).
I hate making decissions ....... LOL
roger, IMHO forget the uprated vertro with a tuned turbo motor
i whent down this way myself
and it just wont cut the mustard over 10psi of boost for a figure!
stick to the pre vertro & go for an orange cover
if this does not hold out go for a gray all the way!*wink*
if your using a cam of say... a duration of or over 260 deg
lighten the flywheel and backplate & have all the rotating assembley ballanced, it makes for smooth quick picked up motor
RogerM
Member #: 1217
Cheers for the feedback..
10 psi is about where it will run, 12 psi at a push........
Cam is likely to be a NA MG Metro cam as I am only looking for a little extra sparkle .... no bannana trees here
Orange still looking fav' although it is unlikely to get reved hard and smooth gentle response is more important than a snappy throttle so I am planning on leaving all the standard flywheel and backplate components in situ .... just a quick freshen up of the friction surfaces.
