Home > Help Needed / General Tech Chat > Brake master cylinder ... front / rear tandem type non servo
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
As my poor old turbo is miles away in storage I can't peek under the bonnet to get the part number off the master cylinder. Anybody here know which one is the front rear split tandem master cylinder????
I know there are three types;
Front rear split
Diag split
late servo type.
The girlfriends build has single line brakes and as I always change them as a mater of course I thought I'd go for the IMO safer split front / rear system.
Cheers.
P.S. if anybody knows the part number for the correct system valve to go with that it would be great .... Although I think there was only one for front / rear split......
miniminor63
Member #: 672
The oversills police
Oslo, Norway
GMC227 with the yellow tag.
RogerM
Member #: 1217
Cheers miniminor63 ..... will look for one of those.
miniminor63
Member #: 672
Oslo, Norway
http://www.minispares.com/Product.aspx?pid=36659
there it is. This type is commonly mounted with one circuit (upper one IIRC) to the front circuit, and the lower one to the rear circuit. inline with the rear there as often mounted a bias valve to limit the rear brakes.
I have it like this on my car now and it works.
BUT recent thinking and reading makes me wonder why it works.... The two pistons in the master cylinder are connected, so if we limit travel in one of them, the other will also stop.
When we limit the pressure that we can give to the rear circuit(lower piston) we will limit the travel of this piston, and therefore also limit the travel of the upper (front) circuit..... hmmmm
RogerM
Member #: 1217
I thought the upper on was the rear and the lower the front as the upper the larger diameter piston is the lower one IIRC. I would have thought you had to move more fluid to engage the brakes on disc calipers (especially 4 pots) than you do the rear wheel cylinders ..... I am happy to be proven wrong though.
I also thought that the two pistons where not physically connected but via a plunger and spring to give some possible relative movement between the top piston is floating. Also the rear brakes have positive return via the springs which could return the upper piston in a semi floating arrangement .... again I am happy to be proved wrong on this.
Edited by RogerM on 30th Dec, 2006.
miniminor63
Member #: 672
Oslo, Norway
its all about pressure, not volume in a brake system as its already full of fluid. A small cylinder makes more pressure than a big one with a fixed amount of travel.
Your last point is interesting, and may be the reason why it works:)
