| Home > Help Needed / General Tech Chat > drilling a head for 11 studs at home? | |||||||
30th Dec, 2006 at 07:04:16pm
finally got my head today, got it home and started painting it up and realised that it hasn't been feckin drilled for 11 studs, my blocks already drilled and through into the water gallery on number 1 side so i've got to drill the head myself now and fit the stud.
30th Dec, 2006 at 07:13:05pm
12.5mm drill bit springs to mind. Give me a few mins and I'll wander out to the garage and measure.
30th Dec, 2006 at 07:15:01pm
Use a head gasket as a template,the holes should be quite a bit bigger than the studs,look at the size of the outer holes on a 9 stud head
30th Dec, 2006 at 07:24:14pm
start off with say a 4mm pilot drill then to say.... a 8mm and so on ....
Edited by BENROSS on 30th Dec, 2006.
30th Dec, 2006 at 07:28:29pm
I lied it's 11mm
On 30th of Dec, 2006 at 07:13pm British Open Classic said:
12.5mm drill bit springs to mind. Give me a few mins and I'll wander out to the garage and measure. Isambard Kingdom Brunel said:
30th Dec, 2006 at 07:34:18pm
yup, just been out measuring, my 10mm drill bit is a bit too small so i was going to use 11mm.
30th Dec, 2006 at 07:51:31pm
should be fine .... might have fun getting the holes perpendicular to the gasket face .....
30th Dec, 2006 at 09:13:40pm
My old man has a proper large pillar drill he'd probably let you use for 10 mins, he is based near Redditch.
30th Dec, 2006 at 09:45:58pm
cheers for the offer Tom, but Karl's stepped in to lend a hand again. He's going to run it into his work in the morning and drill it for me. i just didn't fancy ruining a few hundred quids worth of head with a nutool drill.
31st Dec, 2006 at 10:20:01am
Glad you got it sorted Every day is a school day ...........
