Home > General Chat > Dash alternatives.
MarkGTT
Member #: 1194
Shropshire.
Hi all, I had a quick search on here for details on digital dash displays to see if anyone was using them and how you got on etc, seems like a few of you were contemplating getting one, just wondered what you opted for and how your finding it.
Cheers.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Still contemplating here ......
Will probably go for one of these;
https://www.pmtuning.co.uk/Merchant2/graphi...BA011B00-FP.gif
more details here
https://www.pmtuning.co.uk/Koso%20tec%20page.htm
I think that will do everything I need it to do for sensible money and it comes with all the sensors etc.
RogerM
Member #: 1217
These are ok but at 65mm a little small.
http://cgi.ebay.co.uk/DIGITAL-SPEEDO-REV-A...tem200020751387
RogerM
Member #: 1217
Of course if you want data loging etc. then your into the SPA stuff and similar but then you need a mortgage just to order the manual.
MarkGTT
Member #: 1194
Shropshire.
Cheers Roger, both look good but as you said the latter might be a bit small.. the only down side to the first imo is the scale of the rev counter not much will be used on a car..
i like the look of the acewell 3150
http://cgi.ebay.co.uk/Digital-Dash-FREE-PO...bayphotohosting
any thoughts?
anyone using this?
RogerM
Member #: 1217
should work ok.....
same thing with the rev counter as it's meant for a bike as well.
Looks duller than a labour party political broadcast ... (hopefully more accurate!!!)
small display and I personaly prefer an anologue / needle for revs ....
Will do the job though and half the price of my choice....
Edited by RogerM on 2nd Jan, 2007.
Dicanio
Member #: 91
i've got one of those, got it mainly for the speedo as i've mounted a rev counter as well
MarkGTT
Member #: 1194
Shropshire.
all working ok? easy to fit etc?
RogerM
Member #: 1217
Where did you mount the speedo pick up?
I am in several minds;
1) on one pot joint
2) make up a unit to sit on the end of the speedo drive output ...... (over thinking it again proberly)
3) Fit the pick-up into the case near the diff and hope the oil doesn't kill it.
No doubt 1) is easiest.
MarkGTT
Member #: 1194
Shropshire.
in the rear drum?
johnK
Member #: 690
Norfolk
in the rear drum outer flange is easy/ drop some cap heads into the rim (easy on ally drums - I've used 5 equi-space on my gold car - works perfect)) - then wheelspin doesn't corrupt it - on the pot joints is good for traction control and launch control - but a non driven wheel is the best control signal. Then the sensor ( K series cam sensors are a good size)can be mounted up by the shock using the backplate bolts for a mounting bracket.
If Carling made Mini engines
RogerM
Member #: 1217
Good plan that man!!!!
Lance Link
Member #: 1174
Sunny Southern California, USA
There are a few options available on the Acewell website on how to connect their speedos. They even sell an adapter that connects to a speedo cable drive.
http://www.acewell-meter.co.uk/en_uk/speed-sensor/index.htm
61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
www.motorlust.com - The Online Magazine for Car Guys Like Us
MarkGTT
Member #: 1194
Shropshire.
cheers chaps, think i might opt for the acewell
looks like the best way of doing it, thanks lance *smiley*
