| Home > Help Needed / General Tech Chat > water fed turbo, oil and coolant considerations | |||||||
2nd Jan, 2007 at 02:55:08am
For those of you who dont know my wee story, I fitted a turbo to my nat-asp engine, turbo was mint on installation.after not many miles the turbo started smoking, if you pulle dthe sparkplugs they wee all squeaky clean and fine, BUT shitloads of blue smoke out the exhaust. this got worse and worse to the point where i notice dhte compressor wheel was now fouling the housing! knackered bearings.
2nd Jan, 2007 at 03:26:13am
That looks pretty normal for the 'colour' but the scoring shows it is in poor health clearly...
Edited by turbodave16v on 2nd Jan, 2007. On 17th Nov, 2014 Tom Fenton said:
2nd Jan, 2007 at 03:33:01am
ahwell. im cool in that respect then, i jstu get the magic "whooooooooooosh" and away i go :) .. its a 1.4! turbo 16v k-series 11.9@118.9 :)
13th Jan, 2007 at 01:53:32am
finally got some decent weather so got soem figures. a k-type thermocouple lowered down the dipstick tube into the sump recorded an oil temp of 105 degrees after a reasonably hard run and an infra-red thermometer made the core of the turbo at 146 degrees.
13th Jan, 2007 at 09:57:18am
I'd say that about 90deg is the lower limit and around 125-130 the upper limit. After talking with a couple of major oil suppliers these figures seem to the accepted design targets and what we tell our customers (who are vehicle manufactures) we have rated our components for. Every day is a school day ...........
13th Jan, 2007 at 10:34:51am
Are you actually getting an adequate flow of oil to the turbo?
13th Jan, 2007 at 03:33:14pm
I assumed i was, as there is no "blueing" ofthe shaft and the wear is predominantly at the turbine end, the ID of the hose and fittings is at no point smaller than the origional rover oil feed hose the first turbo came with :( if it was oil starvation i'd expect discoloration of the shaft from heat, and relatively equal wear on both bearings tbo.
Edited by evolotion on 13th Jan, 2007. turbo 16v k-series 11.9@118.9 :)
13th Jan, 2007 at 09:31:33pm
think id stick a guage take off at the turbo inlet to make sure there is oil pressure at that point all the time ,especially when wizzing round sharp bends .!
; but having never experienced it myself I can't honestly explain in more detail. All I do know is that is you're listening out for the above kind of sound, then you'll instantly recognise the noise above the normal engine/turbo noise...
