Home > Help Needed / General Tech Chat > heater and choke cable route through turbo box????
daniel_johno
Member #: 751
Aberdeen
I have recently got my mini shell back from getting the body work done and the turbo box welded into place. I now notice the turbo box has replaced where the choke and heater cables used to pass through the bulk head.
Do i drill into the turbo box for the cables to pass through in a straight line from where they are posistion on the dash or will they foul the turbo? and do i have have to run them some other way?
Thanks for looking
Daniel
Richie
Member #: 628
personally i would not run em past the turbo box, but to either side of it, keeps em away from the heat and will prevent any jamming or crimping....but thats just me :) did you fit the subframe ok ?
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
daniel_johno
Member #: 751
Aberdeen
yeah subframe went in fine, just a shame the rear wasnt as easy with the minispares adjustable camber brackets miles out of shape.
As richi says
i would keep the cables coming out as near as practical to the original place
by re drilling
forget the turbo bulk head box position you mentioned
daniel_johno
Member #: 751
Aberdeen
On 4th of Jan, 2007 at 05:54pm BENROSS said:
As richi says
by re drilling
Problem being i cant rememeber where they origionally came out so dont know where to drill.
Does anyone have a pic of where the cables pass through the bulkhead,
Thanks
Daniel
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Try to put the minimum bend (certainly not kinked at all) and most direct route. Should be ok. Also try to kepp it away from anything it can catch on or that can damage the cable itslef.
