Home > Help Needed / General Tech Chat > what torque should the big bolt that holds the subframe be???
clubminiflip
Member #: 54
nr coventry
what torque should the big bolt that holds the front subframe on be??? bulkhead end *surprised*) the one you take off to fit hi-lo's, i cant find what it should be, also if i replace them with alloy bolts is the torque less, cheers again
Edited by clubminiflip on 7th Jan, 2007.
Front Subframe Turret Bolts are 67NM, which is about 50 ft/lbs.
I don't think it's in the Haynes manual anywhere, I know I had trouble finding it when I did mine up the the other day, but luckily TM came to the rescue:
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=11246
Also 1 foot pounds = 1.35581795 newton meters
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Standard bolts are aluminium I believe, but a really poor grade.
Fastcarl or JohnK will be able to tell you about their subframe bolts and the advantages.
I am not doubting Robs information but as standard I have never found any that are really above what I'd called nipped up. How you can have a reasonable torque value when as standard it is compressing two bits of floppy rubber which will relax is beyond me.
67NM seems reasonable for solid mounts though
clubminiflip
Member #: 54
nr coventry
hi again, just want to confirm the toeque for subframe tower bolts chaps, what is it??? is british open classic on the money with his figures above??? cheers
I'm sure its about 50ft/lb too, and the std bolts are steel.
Im fairly certain they are steel, they feel to heavy to be Aluminium!
some are steel, some are alloy! i've broke cars with both.
RogerM
Member #: 1217
Interesting, only ever had cars with ali .... trust your statements though.
clubminiflip
Member #: 54
nr coventry
well i've torqued mine to 50lbs & alls well, used a lil copper slip grase on the threads too! i think mine are steel turret bolts, no probs at that torque with mine & my subframe is solid mounted
How'd you manage to break them, especially the steel ones, there big ol' boys! Lol
wow! never seen an ally one! have to keep a look out for that.
Dangerous
Member #: 417
My bolts are steel,found out when I drilled a hole through them for the adjustable hieght allen key
