Home > Help Needed / General Tech Chat > lowered front shock mounts
clubminiflip
Member #: 54
nr coventry
lowered front shock mounts! when sould these be purchased & used, is it when you use the lowered shocks? cheers again chaps
mmmm good question.
to me it looks like a one or the other situation.
the shorter shocks are to prevent the shock bottoming out, the brackets are supposedly to put the shock at a better angle, but they do raise the top of the shock too, i think that the standard lenth shocks and the brackets should stop any bottoming out unless the bump stop is chopped down.
Could be wrong though!!
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Normally use both if the car is over 30mm lower than standard... always worked for me.
MarkGTT
Member #: 1194
Shropshire.
I was told to use them when you lower the car on adjusters etc… so I did. *wink*
clubminiflip
Member #: 54
nr coventry
so i should be using a set now i have my hi-lows fitted, i thought i only needed lowered shocks, my car will have about a 1" gap between the tyre & arch edge front & back, will i require a set of these lowered mounts, where do i get them, i only ask cause i've only just heard about them, bet they've been around yrs too
MarkGTT
Member #: 1194
Shropshire.
i got mine from mini spares as below, the write up tells you a bit about them, hope it helps.
http://www.minispares.com/Product.aspx?pid=34805
RogerM
Member #: 1217
Min-Its stock them too ....
