Home > Help Needed / General Tech Chat > How to check the psi of an actuator
Stig
Member #: 694
Shropshire
Hi all
Recently I purchased a t2 turbo off a renault 5 however I cannot move the actualtor by hand like i used to with the actuator off the t3. Does this mean its knackered?
If not what would you surggest to free it up. Also is there any way of checking the psi output of the actuator?
Turbo Shed
Member #: 30
Epsom, Surrey
R5's run higher boost so the actuator is stiffer
Stig
Member #: 694
Shropshire
Not suprised about the higher boost but i need a pair of pliers to move the actuator
high psi actuators are bloody strong
i've got a 14psi (think renaults are 10psi) and its very very hard to move.
metro's are very easy, probably the lowest rated actuator you can get i'd guess.
oh and to test, some sort of air supply, bleed valve/regulator, and a boost gauge will show you how much pressure it takes to start to move the arm.
welshdan
Member #: 1111
s wales
so what if i put a mg metro actuator with a recon nissan pulsar turbo? sorry 4 stealing the post, need to know tho!
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
4psi of boost before a bleed valve I'd have thought.
As a rule of thumb try to use the highest rated actuator you can for your min boost requirement, much better than bleeding loads off IMHO
Turbo Shed
Member #: 30
Epsom, Surrey
or get a boost controller as they done bleed off air
RogerM
Member #: 1217
Even better but aren't they slightly pricey?
Turbo Shed
Member #: 30
Epsom, Surrey
they can be and thats why ive got a bleed valve. i will get one at some point.
Sounds about right to me. my 15psi one is unmovable. I use a footpump to force it out when putting it on. but the old 4psi one was easy to move.
I have an R5 T2 one at home somewhere, I'll see what it's like if I remember.
as a (very!) rough estimate...
times the area in sq inces of the actuator diaphram by the pressure it will see, tis will be some where near the weight of the spring
t3gav
Member #: 229
Gavin@minispares.com
kent
Pulsar turbo is way too big for a mini btw!
RogerM
Member #: 1217
Can also use an airline, most painting regualtors are quite accurate.
