| Home > General Chat > Bling! | |||||||
12th Jan, 2007 at 06:03:33pm
http://www.7ent.com/detail.cfm?pageid=1894
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
12th Jan, 2007 at 06:05:39pm
with that sort of price tag i think ill be giving it a miss
12th Jan, 2007 at 06:28:01pm
I always thought (right or not ?) that the function of a crank damper was carefully calculated weights connected by the damping medium (rubber in this case) if the weights are changed the damping frequency will be changed.
Edited by danboy on 12th Jan, 2007. |
1425 Posts Member #: 690 Post Whore Norfolk |
12th Jan, 2007 at 06:48:38pm
danboy - correct explenation - the "mass" of cast iron on the rubber section will resonate at a pre-determined frequency - engine speed to counter act the 3 bearing crank having a whobbly attack and making the engine feel/sound harsh! - the reciprocating assy (crank/rods/pistons)will go through more than one reasonance point, the mass damper is there to take the worst one out. The alloy damper in the link is also on an elastomer but due to the mass being much lower, unless they've made the outer ring larger or used a harder elastomer - it will likely have a useful mass damping effect very very high up the rpm range - it takes specialist equipment to measure these devices and develop the damping effect - not easy things to design.
If Carling made Mini engines
12th Jan, 2007 at 07:03:58pm
so all the pulleys machined by Tom F and the like will move the damping frequency up in the rev range then? |
12th Jan, 2007 at 07:04:44pm
John, couldn't have put it better myself. Just one thing, my brain is telling me that the elastomer would need to be softer to have the desired effect?
12th Jan, 2007 at 07:06:51pm
That is a good point. However, i'd expect the people that mades these, have taken this into consideration.
12th Jan, 2007 at 07:40:42pm
Ok, here we go I am sticking my neck out on a subject I am not qualified in but maybe logical thinking might help.
12th Jan, 2007 at 08:04:22pm
Of course everybody on here is getting the damper machined first then having the engine balanced afterwards .... surely?
12th Jan, 2007 at 08:15:30pm
I have the S one, its two piece, so it can not be "reproduced" by altering the other type. you can get the S ones new. Mine are new and machined like Tom does. Its balanced after that. I have broken a rod bearing after this, but that was not close to the pulley and is believed to be of another reason. |
12th Jan, 2007 at 08:21:22pm
Andre How do you mean "two piece" can you put a picture on to explain to me. Please!
12th Jan, 2007 at 08:47:24pm
http://www.minispares.com/Product.aspx?pid=33426
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
12th Jan, 2007 at 08:49:48pm
i have a romax damper for my engine, the timing stamps are the wrong way round. Swiftune sell them if you want a uk supplier, last time i checked it was £140ish inc del. I've seen the future and tbh its Pie
12th Jan, 2007 at 08:51:42pm
one thing to remember, that standard dampers are NLA. Cooper s ones are kindly reproduced by Mini Spares. On 26th Oct, 2004 TurboDave16v said:
12th Jan, 2007 at 09:25:07pm
On 12th of Jan, 2007 at 07:40pm danboy said:
Ok, here we go I am sticking my neck out on a subject I am not qualified in but maybe logical thinking might help. By machining timing grooves round the perimeter will up the threshold where the damper works but not by a significant amount. The rubber in most cases will be years old and much harder than when new and this also will move the resonant frequencey up the range? How many of us give a thought to replacing the damper to restore it's correct function? The ali damper would need to be considerably larger than the steel one to have the same effect and the engine mounting bracket will not allow a big enough increase in diameter for the damper to be effective. I have read in parts suppliers lists that the old cooper s damper is the one to have, Well if you remove the fixing rivets from the rear of a later pulley and remove the disc you finish up with a damper that looks (is) identical to a "s" one, At least the two in my garage do. Regarding the missing tooth, on a 36-1 set up, upsetting the balance ao the engine. If any of us has an engine balanced that accuratley that is makes a difference why don't they just drill a hole diametrically opposite into the front face of the pulley to remove the required weight and all will be OK. Remember it's only at a radius of 50mm or so. There is probably lots more imbalance created by an unevenly worn starter ring gear. One final point and it's not a dig at anyone but I think it's a little nieve (SP) to assume that all parts manufacturers do the correct amount of R&D because they do NOT. Regards Dave As i would expect from your good self Dave , another well thought out and written responce, and what you said about the r+d being almost non existant, is almost certainly true, if the alloy damper in question is a one piece then its a bloody expensive "pully" as thats all it is, as i understand things the heavier the flywheel you need a proportionally heavier damper, which i will confess to not considdering in my engines due to there short running lifes,i use solid alloy pully's to save weight, altough the crank tails do show signs of very slight fretting up against the "C clip" usually on flywheel removal its something i'm prapared to accomodate. another point to mention that when Tom has his dampers machined he has produced a spread sheet to help work out the imbalance and tells you where to drill a hole and how big to drill it in different diameters. but as roger M suggests most will be having a dynamic balance anyway , like myself spending three hours balancing my rods and pistons this week , which is the easy bit , i will have to enploy the services of an engine shop for the crank and clutch assy's. so if its bling your after i'm sure either me or John K could happily take your hard earned wedge for a lump of turned alloy, carl |
12th Jan, 2007 at 11:40:29pm
Andre/Mini Sprocket,
