| Home > Help Needed / General Tech Chat > twin fuel tanks | |||||||
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
13th Jan, 2007 at 01:07:22pm
Can i run twin fuel tanks with fuel return pipe fitted. |
13th Jan, 2007 at 03:07:20pm
No reason why not but you really should do the follwoing to my mind.
13th Jan, 2007 at 03:53:41pm
Hi, i run twin tanks, i have a right hand cooper 's' tank.
13th Jan, 2007 at 04:58:24pm
thanks, tanks now on order.
314 Posts Member #: 1311 Senior Member Yeovil, Somerset |
13th Jan, 2007 at 05:11:22pm
Surely the fuel feed from the left hand tank should be seperate from the balancing pipe between the 2 tanks if your return is only fed to the left tank?
13th Jan, 2007 at 05:28:09pm
Not really, so long as they are linked the pump will produce a certain amount of suction and the fuel will come from where ever has the highest head. That will ultimately even itself out.
Edited by RogerM on 13th Jan, 2007. Every day is a school day ...........
13th Jan, 2007 at 05:41:24pm
the fuel will always find one level if the pump is situated after the balance pipe tee piece, for instance if both tanks were empty and you only filled the left tank the balance pipe will feed the right hand tank making the fuel level. |
13th Jan, 2007 at 05:52:51pm
Your right Mark, the only thing is how long it takes.
13th Jan, 2007 at 07:24:39pm
good point Roger, but if you get it that low you better be on your way to a petrol station! lol . |
13th Jan, 2007 at 08:19:44pm
Agreed but there has been occasion it's got that low on the road trying to find a Shell station. Also when on track I like to have as little fuel on board as possible, not only so I'm not dragging loads of weight around but also when some idiot runs into me there is less to leak out. Every day is a school day ...........
14th Jan, 2007 at 10:24:09am
I was thinking of running a ballance pipe between both tanks that just links the 2 and then put a seperate supply fitting on the left hand tank. Doing this the tanks should always be ballancing each other as the supply will be taken from else where
14th Jan, 2007 at 11:30:01am
Anything that equalises the tanks will help... Every day is a school day ...........
