Home > Help Needed / General Tech Chat > gudgeon pin movement!!!!!!!!
fordimus maximus
Member #: 1357
telford,shropshire
bought some used metty turbo pistons and found that there is movement on the gudgeon pin, up and down!!!! just thinking if i fit them they will nock? compared them to ones that i removed and there is no play in those at all!!!!!
do i need new pistons?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
you need to find out whats wrong thats for sure...
Alex
AlexF
fordimus maximus
Member #: 1357
telford,shropshire
is there any chance that the pins are worn and not the pistons, in my mind the pistons would wear before the pins do. was thinking of pressing a pin out, then fitting one of the standard pins in to see?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
getting the pin out NEARLY always destroys the piston.
(assuming they are interference fit)
Alex
AlexF
Doodmeister
Member #: 149
Alberta, Canada
Sounds to me like the wrong PIN for the pistons...
And it depends on who and how you remove the pins Alex :)
Alex
What? Get someone else to do it then.
Wrong. What happens is that small debris contaminates the aluminium alloy in the soft piston. This wears down the pin, althought the pin is harder. Take a look at rocker shafts. Why do the shafts always wear more than the soft bronze bushes inside the rocker arms. Same think happens.
Previously I've removed gudgeon pins and had them pressed in 90 degrees differently. Although a bit bodgy, and not a long time fix, I achieved what I needed. I always store gudgeon pins when a piston is binned as well. For these incidents.
