Home > Help Needed / General Tech Chat > Inner wing crack - MOT failure?
Neil8p
Member #: 65
South Yorkshire
Spotted a crack near the o/s top shock mount. Will the car fail its MOT on this?
Thanks
Neil
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Depends on how picky he is. By rights he should fail it as it's close to a shock mount.
I would be wanting to get it sorted anyway and welding in that location isn't too difficult so even if you have to pay somebody it should be a cheap repair.
dunno, its not structural, but it is close to what could be considered a 'suspension mount'?
eitherway its 2 secs with a welder and a lick of paint
I doubt very much that an MOT tester would notice it as it will be covered mostly by the shock absorber. BUT, if he does see it, it will fail as it is a structural defect in the vicinity of a suspension mounting point.
Paul
RogerM
Member #: 1217
Surely somebody from this forum will be able to help you out, if you where closer I'd do it for a pint .... probably best to make sure they get the pint after the job ...... :)
danboy
Member #: 1381
just weld it anyway!
regards
dave
Neil8p
Member #: 65
South Yorkshire
Cheers for the quick replies. I thought is was a possible faile as it's so close to the shock mount.
I have a welder but it's a long time since I've done any. I'll have a practise on some scrap and see how I get on. There's a couple of people who might be able to help me out if I get stuck :)
TBH I'd weld it what ever, its you thats driving the car and if it suddenly gives way then it wouldn't be pretty!!
AllanMcD
Member #: 414
Dalbeattie Scotland
Mine failed yesterday for a hole in the same area but I welded it up last night it should be ok for a retest early next week.
Allan
http://www.rabdunn.co.uk/
Run a weld up it like everyone else has said kid. Shouldnt be too hard!
Richie
Member #: 628
Paul
yeah its within 30cm of a structure zone (the shock mount) however a quick wix would be to fill it and spray under seal over it (what he cant see he cant test) or seem weld it up bud :)
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
RogerM
Member #: 1217
Go see if your horse is ok .... there were a few indians eying it up ....... LOL
Neil I'll weld it you no problem buddy.
Neil8p
Member #: 65
South Yorkshire
Cheers Tom, you were one of the people I had in mind :)
Turbo Tim
Member #: 177
Avon Park 2006 Class D Winner
Woburn Sands
I cut my inner wings out, my past mots
16V project underway
RogerM
Member #: 1217
If it's not there they can't test it ....... if it is there they can fail you on it.
The same rule applies when building kit cars and the like. Even though a Q should be tested as a '72 if you fit things that can be tested they must be mounted correctly and work, fog lights being the biggest offender.
MOT testers are a funny bunch.
Richie
Member #: 628
hot dang yeehaa rawhide :)
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
