| Home > General Chat > turbodynamics.co.uk | |||||||
![]() 253 Posts Member #: 851 Senior Member Hereford |
13th Jan, 2007 at 09:14:39pm
Anyone used them?
13th Jan, 2007 at 10:59:37pm
Quite cheap but they didnt want to tell me any info on how they balanced their turbos and the guy was a bit of an arse, on the other hand turbo technics were very good and are proven, they cost a bit more though. Just my 2p's worth :) |
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
13th Jan, 2007 at 11:44:41pm
im using gb turbo solutions, just had my turbo done there, good customer service, cost me 475 for a stage one turbo setup, usually 315 but needed new core and exhaust housing "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
14th Jan, 2007 at 12:29:57am
I'm looking at getting the turbo better than standard, just so I have something to play with :)
32 Posts Member #: 1119 Member |
14th Jan, 2007 at 09:48:56am
I bought a turbine shaft from them a few years ago and had a look around their facility. They have got a VSR to balance turbos and seemed quite helpful when I visited and competitively priced. |
3596 Posts Member #: 655 Post Whore Northern Ireland |
14th Jan, 2007 at 01:13:06pm
TD are one of the bigest turbo guys in the UK.
14th Jan, 2007 at 01:17:58pm
I'm not doubting their work, just wondering if the're worth the money :)
14th Jan, 2007 at 01:40:50pm
what spec turbo are you going for and why? "Turbo's make torque, and torque makes fun"
14th Jan, 2007 at 01:45:52pm
I'm aiming for around 150-170bhp, and I want the most reliable turbo possable, and something that can cope with that sort of power....
14th Jan, 2007 at 02:32:39pm
what turbo do you have for a start
14th Jan, 2007 at 02:39:11pm
On 14th of Jan, 2007 at 01:45pm Dogmatix said:
I'm aiming for around 150-170bhp, and I want the most reliable turbo possable, and something that can cope with that sort of power.... I also want a free spinning turbo, with proper bearings etc A standard RS Turbo spec T3 then 8-) AlexF |
14th Jan, 2007 at 04:10:58pm
I may be wrong, but I would hazard a guess, that Avonbar outsource turbo work ??
14th Jan, 2007 at 05:00:38pm
I have a Metro T3 atm.
14th Jan, 2007 at 05:49:00pm
The compressor cover is different, so not strictly speaking.
14th Jan, 2007 at 06:10:50pm
I just asked for a metro t3 with a 0.36 exhaust housing and they said that it'd be fine no extra cost etc, i assume this will work? |
14th Jan, 2007 at 06:36:01pm
A/R numbers I am still trying to learn atm!
14th Jan, 2007 at 08:11:43pm
On 14th of Jan, 2007 at 06:10pm gav said:
I just asked for a metro t3 with a 0.36 exhaust housing and they said that it'd be fine no extra cost etc, i assume this will work? I think all that would do, is make a metro laggier. It may help a little at the top end though, as it will be less restrictive. I think the regular Metro housing is a 0.28 ? It a straightforward swap, no special tools required. Ideally its a larger compressor you want though, not a turbine housing. 9.85 @ 145mph
14th Jan, 2007 at 09:06:54pm
I thought most people upgraded to the escort size exhaust housing as the original is a bit restrictive, what size compressor would you suggest? or should we invest in a more modern turbo like the new garrett range? |
15th Jan, 2007 at 01:24:05am
On 14th of Jan, 2007 at 09:06pm gav said:
or should we invest in a more modern turbo now your talking sense...... I know I used a 0.36 turbine housing with a 4x4 cossie compressor, inside a modified metro compressor cover. It was laggy, but not so much that it bothered me. With higher compression and better ignition control, it would defo feel better down low that my old car. A more modern unit would defo be worthwhile, but its also going to be more hassle to fit. 9.85 @ 145mph
