| Home > Help Needed / General Tech Chat > miglia arches | |||||||
![]() 439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
15th Jan, 2007 at 06:32:25pm
Was going to order these today but have seen that "brackets must be made to fit these arches" ... anyone know what kind of bracket you have to fabricate/buy .... and why you have to do it with these and not other arches?
NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
15th Jan, 2007 at 06:36:38pm
miglia arches are flat at the edge.
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
15th Jan, 2007 at 06:39:04pm
These need an L-shaped bracket (maybe a bent L) which attach to the underside of the arch and the wing. Most other arches have a lip built in which you can screw through into the wing. Think its been mentioned before so do a search.
15th Jan, 2007 at 08:34:19pm
This is how I did mine too. I had to convert 20 L shaped brackets in to 7 shaped brackets, it took ages.
