| Home > General Chat > Just a quickie... | |||||||
![]() 253 Posts Member #: 851 Senior Member Hereford |
16th Jan, 2007 at 11:03:12pm
Do I have to use a Metro Turbo inlet?
16th Jan, 2007 at 11:33:25pm
The turbo inlet is a little taller than most of the 'stage 1' so gives more clearence under the carb for a heat sheild etc.
17th Jan, 2007 at 07:52:10am
Just been out to look at my engine as it's out of the car. I don't think you would clear the actuator linkage with the carb even with out a heatsheild on a standard T3 but a T2 on an adapter plate may just ....... although I can't be sure.
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
17th Jan, 2007 at 08:19:32am
Mart use the turbo inlet, have a look at bingley hall, should be one there. |
397 Posts Member #: 694 Senior Member Shropshire |
17th Jan, 2007 at 12:46:07pm
I have a metro turbo inlet if that helps which i wond need as i am going the mirage setup. |
17th Jan, 2007 at 05:56:39pm
Well the inlet I have atm, makes my HIF44 with a K&N...
17th Jan, 2007 at 07:59:16pm
Stig, i'd use the turbo manifold with the mirage bits given a choice.
