Home > Help Needed / General Tech Chat > Shielded cable
calum_lorimer
Member #: 318
Edinburgh
I'm amassing parts for fitting megajolt and i've noticed that the wiring i got from the scrappies is all unsheilded.
Do i really need to use shielded cable and if so any ideas where i can get it? I've googled it every way i can think of but havent come up with anything useful.
Thanks
Calum
miniminor63
Member #: 672
The oversills police
Oslo, Norway
maplin have got something you can use I think.
http://www.extraefi.co.uk/products.htm#Loom
just ask for the screened cable *smiley*
I am going to buy some of this and cut the ends off!
Any reason why not?
miniminor63
Member #: 672
Oslo, Norway
no, you can use that, it will get much neater if you only have the correct number of wires inside the cable though. But that may have only the two you need?
Nick
Member #: 154
Midlands
i got mine from maplins
It's just the VR sensor and the PIP and SAW to connect in shielded I believe, so should be OK with a couple of lengths of two core.
miniminor63
Member #: 672
Oslo, Norway
yes, sorry, may have typed a bit fast there. A two core is what you want, is the one on Ebay a two core? in that case its fully useable. If its 5 core it will still be useable, but not neat!
calum_lorimer
Member #: 318
Edinburgh
Is this the stuff i need then?
http://www.maplin.co.uk/Module.aspx?Module...0CABLE&doy=19m1
easier to find when using the right terminology.
Would this be better?
Nick
Member #: 154
Midlands
http://www.maplin.co.uk/Module.aspx?Module...rce=14&doy=19m1
thats the stuff i used i think..
Ben H
Member #: 184
Melton Mowbray, Pie Country
There is a lot of talk about shielding the VR and PIP and SAW cables. If you can then it is worth it. However I have run my car without for a couple of years now with no problems. Better safe than sorry though.
http://www.twin-turbo.co.uk
AllanMcD
Member #: 414
Dalbeattie Scotland
I needed shilded cable for my mini van as it was missfiring I just wraped the cable with tinfoil and taped it up it worked a treat it wasnt for MS or MJ it was the mas air flow meter but the same princaple.
Allan
http://www.rabdunn.co.uk/
t3gav
Member #: 229
Gavin@minispares.com
kent
I used these people www.trigger-wheels.com , very good service :)
Edited by t3gav on 19th Jan, 2007.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
On 19th of Jan, 2007 at 05:53pm AllanMcD said:
I needed shielded cable for my mini van as it was misfiring I just wrapped the cable with tinfoil and taped it up it worked a treat it wasn't for MS or MJ it was the mas air flow meter but the same principle.
Allan
Its not quite the same...
The Crank Position Sensor is an inductive sensor (generates a voltage through electromagnetic induction). As such the voltages can be quite high which can lead to Radio Frequency interference.
Its not a major problem, but ECUs can be easily confused (ghost signals) if the wires run next to each other etc.
Alex
AlexF
Linky????
On 19th of Jan, 2007 at 06:11pm gav said:
I used these people, very good service :)
Edited by Sprocket on 19th Jan, 2007.
Also, only ground the shield at one end, otherwise it becomes a conductor rather than a drain.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Any reason why not?
Well its three core (iirc) and probably melts easily... but it should work.
Alex
AlexF
t3gav
Member #: 229
kent
What a twat, edited lol
T3Tone
Member #: 252
Sunny suffolk
I 2 core screened mirophone cable from maplins.
-MINI CLUBMAN 1380 TURBO-
This just arrived in the post. Only ordered it on Sunday.
Less than £10 for 10 metres - enough for three cars.
And it looks the mutts nuts.
If I'm careful how I cut it up, I may even be able to use the connectors.
Gilesy
Member #: 1067
I found the same thing as you Cal - the Sierra I got my trigger from had no sheild. My loom has though - http://www.maplin.co.uk/Module.aspx?Module...0cable&doy=23m1 is perfect and cheap.
and me!!!
