| Home > Help Needed / General Tech Chat > omega piston help | |||||||
![]() 213 Posts Member #: 249 Senior Member |
10th May, 2004 at 12:32:41pm
does anyone have a idea what is the max power that the non forged omegas are safe to?? |
10th May, 2004 at 01:04:39pm
I run 18psi on a set of non-forged Hepolites. Not sure how long they're going to last though.
10th May, 2004 at 01:07:33pm
Well i personally would say 20psi on those with under crown cooling. There are a fair number of people use them, cant say i know many using forged although i think giallofly is. |
10th May, 2004 at 01:31:33pm
no real need to forged pistons unless you want a bigger dish than 10cc which comes in the cast pistons. I run cast pistons, over 150bhp,, no problems On 15th May, 2009 TurboDave said:
10th May, 2004 at 05:09:35pm
I'd have thought RPM, Heat and Mixture are the killers of pistons, NOT boost.
10th May, 2004 at 08:58:45pm
True Dave but more boost is more BMEP and eventually you'll find the structual strength of the std piston design...
AlexF |
10th May, 2004 at 10:27:21pm
Those cast 10cc omegas will do the job, mine ran 22 psi on them with healthy BHP. provided the engine is set up correctly they are sorted. Your engine is basically the same spec as mine that did a 13.62 quarter and would show most things a clean pair of heals on the track.
