| Home > Help Needed / General Tech Chat > Standard 8.4 inch disk stopping capability | |||||||
22nd Jan, 2007 at 08:54:55pm
Just had a search through old posts on brakes and didn't really find a definitve answer. Would standard 2 pot calipers, greenstuff pads and vented disks provide adequate stopping power a lightly tuned turbo mini? Also how much of an improvement would you notice over a standard set up?
Edited by minimole23 on 22nd Jan, 2007. On 7th Oct, 2010 5haneJ said:
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
22nd Jan, 2007 at 09:08:37pm
Im using the 8.4 setup on my 65hp 998 (non turbo), using drilled and grooved discs, also using ebc green stuff pads, the stopping ability I find satisfactory for the power im producing. considering its non servo assisted. IMO I wouldnt use the green stuff pads again, I much preffered the mintex items I used before, a far better pad.
22nd Jan, 2007 at 09:19:08pm
yes i second that, use mintex, if it has EBC's i'd bin them. with the 8.4's the std mintex compound should be good. I find the uprated 1144 copound good with no servo on 7.5's. they work well enough cold, and as you start pushing they get better, not got to fadepoint yet!! On 28th Aug, 2011 Kean said:
22nd Jan, 2007 at 09:41:28pm
Thats good to hear mini13, opted for those for 7.5" setup on my turbo build.
22nd Jan, 2007 at 09:49:20pm
only thing with them is they tend to be a little bit squeely at low speed/light pressure. That may be the cheap discs though (minispares cheapest ones).
22nd Jan, 2007 at 10:00:41pm
Im going to be running the "uprated material" ones from them.
22nd Jan, 2007 at 11:25:37pm
To be fair the only car I would fit Mintex pads to (1144 or any of their other efforts) is the car of somebody I hate and would like to see die painfully in a horrible fireball.
22nd Jan, 2007 at 11:48:27pm
Ive had mixed use with 1144's
