Home > General Chat > Had a play with a TIG set yesterday.
We're doing a design and make at uni and yesterday we had the workshop induction (milling, turning, benching fitting and welding).
fortunately i've done my apprenticeship and dabble quite a lot so ended up with some spare time at the welding since i was fine migging (btw, the setup i used was 100times better than my own and produced perfect weld! wasnt an overally expensive bit of kit apparently).
I asked if i could have a dabble at tig'in and the bloke was more than happy to show me.
Certainly different but good fun. hoping to do a bit each week and take my K1100 rocker cover in for modding.
Much harder having to use the pedal and both hands whilst welding!
still all good fun, and hopefully a place to get a few bits done over the next year or two!
*smiley*
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Have you done gas welding before?
I found tig much easier, even though you need to use the pedal!
Was it a proper auto-start etc?
Alex
AlexF
yeah proper auto start etc. ancient thing the size of a mini! lol! worked well though.
nope, never done any gas welding, only mig and arc.
after 5mins it was coming along nicely but didnt have much to practice on.
I havn't had much time on the tig, the one I use has a trigger on the torch which I find very easy to use.
good ain't they!
I use the torch button most of the time, but for thin stuff the pedals well handy, using its a bit like rubbing you head and tummy at the same time. You soon get the hang of doing the 3 things at once though.
biggest tip i can give is keep everything clean, wire brush thogrogly in one direction.
When i went to Vmax I spied Stuarts Tig, that was fooking massive too, looked a bit like one of those 50's fridges.
Edited by Joe C on 24th Jan, 2007.
double...
JT
Member #: 637
Hertfordshire
i would ove to learn to tig.
i know how to gas weld and mig weld but im no expert!
im sure il master mig welding by the time im finished with the mini though lol!
My build thread..
On 24th of Jan, 2007 at 01:13pm mini13 said:
good ain't they!
Thats something Ive discovered too. Im finding say alu 1.5mm upwards reasonably easy ( still dont look too pretty ) but its quite controllable to weld.
But having the workpiece clean really makes a huge difference. As does a clean freshly ground tungsten.
But then I do have a habit of dipping that in the weld lol.
Im getting betetr though ( at least I tell myself that )
Ditto!
I was filing somthing i'd welded the other day (ally) and found a speck of tungsten in the ally, that sure impeaded the filing...
blown_imp
Member #: 598
Gaol
Ditto for stainless welding, i go over the line with a carbide burr in a dremel, its just runs together soooo nice. Nice sharp tungsten too, iveo nly got a scratch start DC unit no foot pedal, can still do this -
Clean Clean Clean!!
J
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off...
Clean Clean Clean!!
J
Are you using filler rod there, or just fusing the 2 metals ??
I only did a little stainless when I got my TIG, and wasnt cleaning the metal properly. I only started cleaning with the alu.
But I could get quite nice welds fusing 2 bits of stainless together. When filler was added, they didnt look so nice....but as I say, I havent tried any stainless again that has been cleaned properly.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
looks to me like there is a little filler rod in there. To be fair that is a nice weld and from that picture it looks like the filler rod has been used only where it is need and then been introduced gently. I'd be proud of that joint...
What would cause the arc to "flutter" for wont of a better description ?
Welding aluminium, it tends to do this on me. The arc isnt always as directional as I'd like either, or is that just normal ?
Dirt ? not enough current ?
Im just cleaning with a stainless wire brush.
I also seem to have used a huge amount of gas...Size Y Argon bottle already gone, and IMO, not a huge pile of welding.
That said, I was having regulator issues as the one they supplied me seems to be poo. I have a floaty type flow meter now though.
Do you have a flow meter?
I bought one and found that I only need a just audible amount of gas, also the flow needs checking every time you start up, I gues tha atmospheric pressure affects the regulator.
also i've had the flutter due to too much gas flow, especially welding in corners.
