Home > Help Needed / General Tech Chat > mpi tank
stevecoolerking
Member #: 155
spotted an mpi tank cheap, i know they got fuel return pipe but is the fuel pump built into the tank? if so does it produce enough psi?
cheers guys
sorry its probably a pants question for your skill
cheers
steve.
Steve, The SPi tank is man enough, so the MPi will be.
I'm after an MPi pump for a different project - if it is a genuine MPi one, would you do a swap?
Dave, jukka says that the injection SPi tanks only produce 1 bar. Not too sure if thats true but its something i will keep an eye on.
stevecoolerking
Member #: 155
im bit skint at mo, so im not buying it till end of month so if i manage to get it and.....
the psi is the same then i dont have a problem with that, waz jukka saying about the psi !
I understood the Rover SPi fuel system pressure to be 2.4-2.9bar...
Good if it is, i thought 1 bar was very low, dont see many injection systems running those sorts of pressures, usually all 2bar + i thought.
Soon find out when i get mine connected up! Shouldnt be that long, next few weeks or so.
I wouldn't have thought that you'd get good fuel atomisation at the injector from such a low pressure...
I do have an SPi metro... If i find a suitable gauge, i will measure the pressure
billydude
Member #: 48
Leicester
I've ran mine at 15 psi'ish boost with my spi tank and pump with no prob's *smiley*
Not ym words, dont shoot the messengar! lol! *happy*
Ill try find the post!
Never known Jukka to be wrong though - which is why i think i'll do the test to see what the SPi system actually works at...
check it out here dave
Edited by iain on 11th May, 2004.
