| Home > Wanted > Cylinder head parts | |||||||
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
24th Jan, 2007 at 07:00:56pm
Hi
Back once again like a renegade master |
24th Jan, 2007 at 11:07:26pm
Let me know whether it is worth buying new valves or 2nd hand. Back once again like a renegade master |
25th Jan, 2007 at 09:12:26am
Buying 2nd hand valves could be OK. What's wrong with the ones you've got? If you need to oay anyone for grinding valves etc you'd be better off fitting new ones. They're less than £10 from Minispares. Then you could bin the rubbish turbo exhaust valves as well. Also, turbo guides are very expensive, and if you ream out standard ones, the nose of the guide will be very thin, and require some attention.
25th Jan, 2007 at 08:22:00pm
I am moddifying a standard 1275 head for a turbo conversion. Back once again like a renegade master |
26th Jan, 2007 at 07:50:36am
Unless you've got some expensive machinery and know how to use it. I'd outsource this. I'd use the standard valves possibly Cooper S size inlets and have these reground and back cut. That's all there is in mine, and it's not that slow. 14,2 sec quarter. On 13th Jul, 2012 Ben H said:
