| Home > Help Needed / General Tech Chat > Honing 1275 little ends for full floating pins | |||||||
24th Jan, 2007 at 11:51:50pm
Are there any reasons not to do this other than increased wear rates. The wear rate is not a problem as it will be stripped after fairly short mileage anyway.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
25th Jan, 2007 at 08:22:27am
your biggest problem is keeping any machining parallel to the big end, this is a serious concideration when bushing, but might be abit easier when its just a hone out. I've seen the future and tbh its Pie
25th Jan, 2007 at 08:57:45am
Im interested in buying teflon buttons for 1275 engines if anyone makes them. Just btw :)
25th Jan, 2007 at 09:40:17am
I've done this to my engine, I can't see any problems. On 15th May, 2009 TurboDave said:
25th Jan, 2007 at 12:28:06pm
When you say converted to fully floating are you fitting bushes or just honing out the rods a little?
25th Jan, 2007 at 12:29:32pm
Why isn't this a good idea in your book? My rods are without a bush. On 13th Jul, 2012 Ben H said:
25th Jan, 2007 at 12:35:46pm
my rods are also without a bush, (but have teflon caps)
25th Jan, 2007 at 12:56:57pm
I think it will not be a problem pin to rod (without a bush) as the pin is NOT rotating, At worst it's only moving through an arc of a few degrees and should be fine.
25th Jan, 2007 at 01:34:57pm
danboy, the laws of real world physics say that it's won't just move in an arc.
25th Jan, 2007 at 01:59:39pm
mine are fully floating and dont have bushes. i took it apart after 10,000 miles and fitted new pistons without holes in the top and the pin felt fine. |
25th Jan, 2007 at 02:28:20pm
RogerM The laws of real world common sense says that it can only move in a small arc each revolution.
25th Jan, 2007 at 05:05:51pm
end of the day if it does wear then fit a bush later |
25th Jan, 2007 at 05:45:04pm
25th Jan, 2007 at 11:15:54pm
danboy you are forgetting the very different loads on the pin at top and bottom of stroke let alone the transients throught the stroke.
