Home > Help Needed / General Tech Chat > Cooling ...
b12
Member #: 247
Kent/Surrey Borders
About to sort out my plumbing !
I can use a mini bottom hose with heater take off; then the sandwich plate of the metro to feed the heater as I have not drilled out my head
Question )
Should i tee off and run a circuit around the inlet manifold ? like standard ?
as far as I know ; heated manifold only have one purpose ; better running when the car is warming up
AM i correct any advice appreciated ...
Oh ... My engine is now in !!: looking good
Solid subframe mounts new cv gaitors, mofifeid plenum for dump valve poly bushs on botton arms and steady bars !!
but ... and it really makes me mad; isnt it funny when you start undoing someone elses work you find horror stories; 4 completely kanckered ball joints that were not even tightened up ..... Oh look no shims either .... then the wheel bearing seals fell out into several pieces .. oh and tir rods that looked like bananas
still should run nice with new wheel bearing and ball joints and tie rods
Steve
Edited by b12 on 10th May, 2004.
TurboLessTosser
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I don't run one... can't see the point.
Its main purpose on most cars is emissions and carb icing to a degree.
Alex
AlexF
