Home > 998cc > What carb ?
Advantage
Member #: 1450
Near Paris - France
Hi all,
Planning to go turbo on a 998 with a 12G295 head, I am contemplating the differcent carb options that I have.
I am not in the mood for injection already as it is more expensive than the carb (each of wich I happen to own already).
Drawbacks on the GT Turbo card is that it is small (big enough for 120 bhp on a 1400 engine though) and will need a self made inlet.
Against the Hif 44 is that it is much too big for a 998 in NA form and I assume it won't help with any sort of turbo lag either.
Thanks for your participation
An HiF 44 converted to Turbo application3 Votes 3 Votes - 0%
An HiF 38 converted to Turbo application0 Votes 0 Votes - 0%
A Renault 5 GT Turbo carb0 Votes 0 Votes - 0%
Rusty by nature
I might be wrong, but i dont think anyone has tried the 2 latter options (?)
if a R5 carb is so small, how do they get round it when they tune them to silly bhp?
I was under the impression they didnt do a lot to get 200bhp (ish)
Advantage
Member #: 1450
Near Paris - France
R5 GTT is 32 mm indeed but I must had that the butterfly assembly is quite slim
Rusty by nature
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Can't really compare a constant displacement carb to a down draft style carb choke size for choke size.
Most of the time a HIF44 isn't up at it's max lift so the effective choke size is much smaller. That is the reason why the HIF is one of the nicest carbs on the market to drive. My 1380 NA motor is pushing out 122BHP on a HIF and if it wasn't for the clockwork dizzy it'd pull from no revs and has awesome throttle response and gives great economy when required. Show me another carb that can do that ..... (I need to change to MegaJolt .....)
HIF44 every time.
