Home > Beginners Tech > plenium brass ring restriction
jacko
Member #: 1460
scunthorpe
is the brass bit pressed into the plenium a restriction? is it a good idea to remove it ?
NO!
i think there is a turbodave post in the FAQ's called "thinking about fabricating your own plenum, read this"
YES
NO
It speeds up airflow over the bridge of the carb, which in turn makes it lift more fuel.
If you remove it, you will need to make some serious mods to the carburettor, to restore fuelling.
Believe me, Ive been through it, and it took me a long time to make it work without the restrictor.. I had my own plenum made up.
