| Home > Technical Chat > what do i need? | |||||||
6 Posts Member #: 1375 Junior Member dunfermline, scotland |
28th Jan, 2007 at 04:50:20pm
ok, im havin a bit of trouble sourcing a metro turbo lump, so i was thinking about buying a standard 1275 mini engine and turboing that..it will be a daily driver (not much of a distance tho) and its got to be very quick, about 5 secs to 60, either 1330 or 1380..any advice i could get from the experts would be greatly recieved, i've done a search on what i will need and so far came up with;
anyone can drive in a straight line... |
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
28th Jan, 2007 at 05:15:57pm
mirage manifold is designed to fit a T2
28th Jan, 2007 at 05:25:27pm
oh right so i'll need the metro manifold?
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
28th Jan, 2007 at 06:29:29pm
T3 will not be as bad on larger overbores as the lag time will be cut down, i am sure any one on here will tell you that any a+ block will be fine to use as a base for a turbo lump they are the same as a n/a block, use the search on this website quite a few people are experimenting with 1380 turbos nowadays, hope that helps. |
28th Jan, 2007 at 06:32:16pm
sorry and as for the head a metro turbo item or a modified n/a metro head that has been modified by a mini specialist will work, and if i remember correctly a n/a is better to use as there is more meat around the exhaust valve but i will probs be corrected. |
28th Jan, 2007 at 06:53:44pm
cheers barkiboi, i'll get on the case. anyone can drive in a straight line... |
29th Jan, 2007 at 07:44:20am
go for 1293 first, plenty of pistons to chose from
29th Jan, 2007 at 06:07:45pm
that sounds abit more reliable right enough, cheers anyone can drive in a straight line... |
