| Home > General Chat > Help with my intercooler setup! | |||||||
193 Posts Member #: 437 Advanced Member Sunny Blackpool |
30th Jan, 2007 at 10:09:47pm
Hi guys,
89' Metro Turbo
30th Jan, 2007 at 10:21:05pm
Trouble is - you need to flow 'through' an intercooler... If you duct up to it (from underneath) then the air needs somewhere to easilly leave afterwards...
30th Jan, 2007 at 10:28:36pm
I do currently have a smallish vent above the intercooler, but this needs properly opening up underneath to be of any use.
Edited by Metro Turbo on 30th Jan, 2007. 89' Metro Turbo
30th Jan, 2007 at 10:44:27pm
Could you not tilt the intercooler down a bit or is there no room (bettery in that corner IIRC)?
30th Jan, 2007 at 10:48:20pm
I moved the battery to the boot, so there is nothing beneath it now.
89' Metro Turbo
![]() 549 Posts Member #: 1347 Post Whore Croydon (South London) |
30th Jan, 2007 at 10:56:59pm
What about something like a naca duct? How good are they at pulling air in as they mount flat without a conventional scoop? Plus i think they look pretty cool. |
223 Posts Member #: 598 Senior Member Gaol |
30th Jan, 2007 at 10:57:48pm
Remember the entry only needs to be about 1/3 the size of the area to be flowed through.
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off... |
30th Jan, 2007 at 11:03:05pm
looking at the size of that cooler, personally i'd look the possibility of putting it where the oil cooler is in front of the alternator, and move the oil cooler. Geting the air throght the IC is more important IMO. On 28th Aug, 2011 Kean said:
30th Jan, 2007 at 11:34:59pm
Put the oil cooler over where the battery was,chop the steel bottom hose and fit a tighter rubber bend.....Then a rs turbo ser2 cooler fits next to the rad up front.
3596 Posts Member #: 655 Post Whore Northern Ireland |
31st Jan, 2007 at 12:50:20am
IC problems aside.....engine compartment looks very neat 9.85 @ 145mph
31st Jan, 2007 at 07:50:23am
^^^Same as above^^^ -MINI CLUBMAN 1380 TURBO- |
31st Jan, 2007 at 04:35:50pm
Cheers :)
Edited by Metro Turbo on 31st Jan, 2007. 89' Metro Turbo
![]() 4641 Posts Member #: 20 My sister is so fit I won't show anyone her picture Lake District |
31st Jan, 2007 at 05:10:28pm
How close is the intercooler to the underside of the bonnet though ? If you use the above design, you'll need space above it for the air to pass through.
Edited by Turbo Phil on 31st Jan, 2007. |
31st Jan, 2007 at 05:22:14pm
I'd say 2 inches between the i/cooler face and the underside of the bonnet
89' Metro Turbo
31st Jan, 2007 at 05:28:54pm
Or there is this way of ducting air to it...
89' Metro Turbo
31st Jan, 2007 at 05:51:44pm
OR... I could just flip the i/cooler by using 90' bends to connect it, and have it mounted behind the inner wing like red 850 has done...
89' Metro Turbo
31st Jan, 2007 at 06:22:07pm
My take on this:-
31st Jan, 2007 at 06:32:13pm
On 30th of Jan, 2007 at 11:34pm Dangerous said:
Put the oil cooler over where the battery was,chop the steel bottom hose and fit a tighter rubber bend.....Then a rs turbo ser2 cooler fits Thats what im doing! :cool: If you dont want to move it i think i would duct air in the top through a naca style vent and out the bottom as thats the way air likes to flow through the engine bay. I was thinking you could try something like peugots have when they have the cooler on top of the engine. They have a duct attached to the underside of the bonnet that funnels in air which goes between the bonnet and grille iirc. |
31st Jan, 2007 at 09:12:17pm
Cheers for all the feedback guys.
89' Metro Turbo
31st Jan, 2007 at 09:19:37pm
The engine will love you for taking that step, especially with your set up. More power with less boost, ace! On 5th of Sep, 2006 at 05:47pm mini13 said:
31st Jan, 2007 at 09:26:52pm
Should have it fitted within a couple of weekends.
89' Metro Turbo
241 Posts Member #: 595 Senior Member stoke on trent |
6th Feb, 2007 at 01:21:58am
i absolutly love your car, ive wanted to see a nice metro turbo for ages, it seems not many people bother with them these days.
