| Home > General Chat > Tig Welding | |||||||
322 Posts Member #: 1158 Senior Member Manchester |
30th Jan, 2007 at 10:45:22pm
TurboDave said
30th Jan, 2007 at 10:59:25pm
A block? what material? hw much welding?
30th Jan, 2007 at 11:04:44pm
Welding of block for plugs for 16v k head conversion so not loads.
TurboDave said
30th Jan, 2007 at 11:11:43pm
I thought the normal practice was to locktite them in? On 28th Aug, 2011 Kean said:
30th Jan, 2007 at 11:18:35pm
Make the plugs from cast iron bar and make them an interference fit. If your really concerned then loctite them in!!!
30th Jan, 2007 at 11:33:37pm
when i had a bras plug move in the head i used a 7 degree taper ream thingy (handy for cleaning up balljoint taper holes) to make a tapered hole and pressed in some tapered plugs with plenty of loctite, I f i were to do a block i'd adopt this approach. The reamer was only about a tenner. On 28th Aug, 2011 Kean said:
30th Jan, 2007 at 11:35:24pm
Good call....... I'd probably leave the plugs a fraction proud so that they'd be taken down easily when the block was flashed .. Every day is a school day ...........
30th Jan, 2007 at 11:42:57pm
the reamer i have looks like this,
30th Jan, 2007 at 11:47:39pm
I thought the magic number for a taper was 14 degrees On 26th Oct, 2004 TurboDave16v said:
30th Jan, 2007 at 11:52:31pm
ahh, do you mean the balljoints?
31st Jan, 2007 at 12:06:41am
Well i said 14 degrees cos thats what we use on the plugs for shell and tube heat exchangers used under pressures up to 300psi
223 Posts Member #: 598 Senior Member Gaol |
31st Jan, 2007 at 12:26:47am
you can weld cast iron, you need a nickel based rod if i remember correctly? Possibly even a flux of some sort? We did a block at an old work place of mine, some rare austin healey one.
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off... |
31st Jan, 2007 at 01:02:29am
I think strength is an issue when using ordinary methods of welding.
31st Jan, 2007 at 06:20:56pm
I welded up a set of cooper S calipers after the bleed nipple broke. :/ |
31st Jan, 2007 at 07:25:27pm
You sure can weld cast iron, nickle rod and arc welder. Not sure about flux as when I have done it I use rods made specifically for the job.
31st Jan, 2007 at 09:09:36pm
I can do it on my grinder. Its accurate too :) |
31st Jan, 2007 at 10:30:38pm
I don't know why you have the idea that the block has to be welded??? No-one else has had to weld a block, so not sure why you see the need? On 17th Nov, 2014 Tom Fenton said:
31st Jan, 2007 at 11:24:19pm
Sorry i miss read something in the guide book.
TurboDave said
31st Jan, 2007 at 11:29:49pm
I think some one on here did weld them in, and grind them back, can't be sure though as i can't find the post. On 28th Aug, 2011 Kean said:
1st Feb, 2007 at 06:58:08am
Ive deffinatly see people weld them in too. |
1391 Posts Member #: 1686 Post Whore Oxford |
20th Jan, 2013 at 10:32:08pm
wrong fecking thread. Edited by Sam on 20th Jan, 2013. On 19th Feb, 2011 Miniwilliams said:
OMG Robert that's a big one |
20th Jan, 2013 at 11:41:24pm
I had a hole in my block welded not sure with what but. I have started posting on Instagram also my name on there is turbomk1golf
22nd Jan, 2013 at 01:32:07pm
On 30th Jan, 2007 dev said:
Welding of block for plugs for 16v k head conversion so not loads. just thinking really. TBH, the sort of welding you require there would be more towards the specialist end of TIG welding. It cast iron, it's a difficult material to weld on it's own, nevermind a huge heatsink of cast iron. And likewise with aluminium. Plus castings tend to be dirty which can make them harder to weld as well. As others have said, I'd look to alternative options if that's the only thing you need the TIG for. Or buy the TIG, but still have that work done professionally. 9.85 @ 145mph
