Home > Help Needed / General Tech Chat > ALTERNATOR - MATIZ
matysb
Member #: 1471
Can You tell me how to chainge the alternator in Matiz ???
In a Daewoo Matiz?
id say thats the best 1st post ever on a mini forum
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
LOL .. but possibly a valid one!!
I was looking in a Matiz for the alternator and it took me a good 10 minutes of crawling around in the mud to find where, and how, it would have been mounted if somebody hadn't beaten me to it......
LOL
If it's any help the following should help.
locate the alternator belt tension bolt and slaken (pig of a job). Undo mounting bolts (12mm IIRC). These are a right royal pain in the bum as you can't really swing a spanner in there.
Undo tension bolt completly.
Remove alternator and make sure you hook the belt over the alternator mount ... if it drops you'll have fun getting it back onto the pulleys.
On the car I have looked at it doesn't look like there should be any cover over the alternator and it is located at the upper driverside rear of the engine bay.
Hope that helps!
now that is pretty diverse!!
nice to se we're no cought out though. LOL
Lol, Loving the post. *laughing*
So Roger I take it that means you've decided to go with the Matiz alternator now!
Did you get hold of one in the end?
*wink*
Anton
Member #: 764
Staffordshire
its a pita.. the alternator is a the back of the engine, right underneath the car, it is possible, but get the plasters on the ready
RogerM
Member #: 1217
Well not right underneath .... LOL
It's a pig alright .... Can be done from above but it's probably best to get the jack out!!
Matty, yes mate I am going to use a matiz alternator but I've not found one yet ..... as I said .. 10 mins to find where is was meant to be!!
jacko
Member #: 1460
scunthorpe
ive done 1, but i did it on a ramp at work n i still got ut knuckles etc
Roger, if you do get one make sure you get the plug for it aswell. *wink*
RogerM
Member #: 1217
More chance of growing an extra leg than finding a plug .... LOL .... unless it's a general motors standard of course ...
If it was that would be far to easy, Let me know how your new leg growing goes. Lol
