Home > Beginners Tech > Dump valve
matt101
Member #: 1457
Hi, iv just brought a standard turbo engine and do not no much about the turbo part. I want to fit a dump valve, but i want it to be loud, anyone have any recommendations? And what i would need to fit it/ where to get it from etc. Cheers
you need a modified plenum from giallofly on this site
and a dumpvalve-i strongly suggest NOT to get a bailey one
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Nic, why do you suggest not to get a Bailey valve?
I have used them on cars in the past but never a Mini. I guess I know what you might be thinking but others may not be aware.
BTW the Forge valve seems good to me!
as i had one, it was fine when it was mounted upside down, but then i changed it when i needed the top hose i was using, and mounting it the right way up caused the petrol to contaminate the x ring seal so that it swelled and stuck open
bailey wont sell me a new seal, instead i have to have the whole thing refurbished for £30
im planning on getting a forge one this year when i have some money
RogerM
Member #: 1217
That is what I thought ........
On carb cars it is best to mount the bailey well away from the carb. Also if you get any petorl down the vac hose it'll do it no good! The answer is to use an isolator valve (basically a diaphram in a air fitting so the vac doesn't act directly on the dump valve. Hardly ideal and buy the time you have bough the valve you might as well have bought a Forge valve in the first place!!!
JT
Member #: 637
Hertfordshire
i bought a forge dv for £26 off ebay and its aperntly 'stuipidly' loud acording to the bloke who had it on his mini before said.
i havent fitted it yet so i carnt say weather its good or not, but the price suits me lol!
My build thread..
blown_imp
Member #: 598
Gaol
Ive got a group A dump valve, with a kevlar diaphragm available for sale if you are interested?
Its the one on the right in this picture -
J
Edited by blown_imp on 31st Jan, 2007.
On 5th of Sep, 2006 at 05:47pm mini13 said:
I reckon if his brains were gunpowder he couldn't blow his own hat off...
Ive used quite a few Bailey DV's and to be honest, they are more reliable than most !!!
Just back from working at a Subaru, with yet another leaky HKS DV. The amounf of leaky HKS and Blitz DV's is a joke. They are total trash.
A friend has had 2 Forge DV's on his Cossie. They work fine, but that stupid foam bit the put around the body falls apart after a few weeks.
RogerM
Member #: 1217
I agree that Bailey stuff s well made and have used them on many injected builds. It's just that the material thet use for the diaphram doesn't like fuel. With a carb system your always going to have a little fuel in the vac line.
Not tried their piston valve with a carb yet.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
You can get different "fuel resistant" seals for the piston type but it seems hard to source these. Avonbar sells them but I think that someone on here says they had no sucess getting them off them. I have the baileys that I'm going to mount upside down and a spare forge I got cheap if that goes pair shaped.
On 7th Nov, 2008 Nic said:
naeJ
m
Ric
Member #: 36
Basingstoke
For the 5 mins that my mini was running i had a piston valve on there... seemed ok, shame about the rest of the car! haha.
As for the not knowing turbo stuff, check the FAQs and beginners tech, worth their weight in gold.
The seal on my one (bailey single piston) has just gone after owning it for 4 months from new!
Turbo Shed
Member #: 30
Epsom, Surrey
i used to have problems with piston DV's sticking, i changed the "O" ring for a smaller/tighter one and it lasted a day or two, then tried grease. this lasted 2 or 3 days the silicone grease, this lasted about a month or so. then i fitted the DV up side down. same DV but never had a problem since
conclusion
if you have a piston DV, fit it up side down and never have another problem
Star Mag
Member #: 375
Leicestershire
Just take them off and leave it in the garage that will sort all the problems!
T3Tone
Member #: 252
Sunny suffolk
I got a quad ring seal made out of viton rubber (no reaction to fuel) from these people
http://www.brammer.co.uk/home.shtml
Edited by T3Tone on 1st Feb, 2007.
-MINI CLUBMAN 1380 TURBO-
she seems happy
it must be the range of 'alternative' rubber products
