Home > Help Needed / General Tech Chat > setting up actuator
how do i do it so im getting the correct boost ?
http://forums.turbosport.co.uk/bbs/showfla...sb=5&o=&fpart=1
Hi, as far as i no all the arms have the same holes in them so you could use a cossie one and weld it on if it's shorter.
as for setting it up, i just start off with just a little tension on it and keep turning it in until you get to where you want.
ive been told 6mm preload
i have a new arm now but my old was a bad casting :(
ive still got this video here lol
I never use that much pre-load - more like 2-3mm, but that is a 14psi actuator...
One other way is to get a gauge and per load the arm pump up the actu with pressure until it moves the arm a little and that might give you an idea on the psi.
I'll PM you my address if you could send it mate that would be ACE , Let me know the return address for any postage and disc costs:)
dont worry about costs i said i would do last year so just pm the address m8
