Home > General Chat > VR sensors
MarkGTT
Member #: 1194
Shropshire.
does anyone know if the VR sensors from a ford differ in length? or are they all the same?
cheers.
calum_lorimer
Member #: 318
Edinburgh
I think the majority of them all use the same type.
I'm using a specialist components trigger wheel and mount and it needs a different sensor, i think the kad setup is the same
MarkGTT
Member #: 1194
Shropshire.
im also using a specialist components trigger and bracket, and the sensor doesn’t fit.... arse.
so i need a different sensor? where did you get yours? how much etc..
cheers
Edited by MarkGTT on 2nd Feb, 2007.
Nick
Member #: 154
Midlands
yeah i was talking to john at the show on sunday and it uses a magnetti marelli sensor i think he said.
Nick
Member #: 154
Midlands
i *think* its this type....only in walsall aswell.
http://cgi.ebay.co.uk/RS-Cosworth-Crank-Se...tem160079626462
MarkGTT
Member #: 1194
Shropshire.
picked mine up on Sunday.. they failed to tell me that when i bought it..
any idea where i can get a magnetti marelli sensor or what it comes off..
Search for sierra cosworth sensors on the bay or ford forums - I'm pretty sure the marelli ones are used on those.
in case its of any use , im using an audi crank sensor!
they are on a cossie
ive got a spanky new one you can have for £20 if you want it, inc postage
let me know
MarkGTT
Member #: 1194
Shropshire.
PM sent Nic.
cheers, Mark.
MarkGTT
Member #: 1194
Shropshire.
cheers, looks like the one! thanks for finding that for me.
with any luck i can have that one from nic. :)
