Home > Help Needed / General Tech Chat > setting up actuator
how do i do it so im getting the correct boost ?
http://forums.turbosport.co.uk/bbs/showfla...sb=5&o=&fpart=1
giallofly
Member #: 164
The Stig..
Newport Pagnell
Wolfie, noticed on that site you are after a plenum, have one with the Montego take off it is any good to you.
its just the take off im interested in m8 how much do you want for it?
Gibbo
Member #: 34
Can't you repair that arm by welding a washer on the end or something?
When I set up my actuator, I connected my air compresser to it and boost gauge, and set my compresser to give desired boost.
Then adjusted the actuator arm to fully open the waste gate.
Expect someone's got a better way though!
