| Home > Help Needed / General Tech Chat > Go on then ..... tell me tell me ACTUATORS | |||||||
![]() 826 Posts Member #: 247 Post Whore Kent/Surrey Borders |
11th May, 2004 at 04:56:16pm
Ok chappies TurboLessTosser |
11th May, 2004 at 05:31:09pm
actuators hold boost better Crystal Sound Audio said:
11th May, 2004 at 11:02:50pm
im going to fit an adjustable boost bleed valve inside, and hopefully uprate the actuator as a future modification after i get it running and on the road. My actuator is pretty new so might aswell give it a bit of use! Do you need to alter the length of the rod on the standard actuator when using a bleed valve? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
12th May, 2004 at 08:50:22am
Or a Manual boost controller (MBC) 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
12th May, 2004 at 10:30:40am
actuator... but the down side is you change your lowest boost setting!
AlexF |
