| Home > Help Needed / General Tech Chat > Gearbox half moon seal | |||||||
69 Posts Member #: 1457 Advanced Member Bristol |
4th Feb, 2007 at 04:27:04pm
I have an oil leak from the half moon seal on the gearbox. Has anyone replaced this seal? Would i get away with loosening the gearbox bolts and raising the block slightly? Or am i gona need to strip the engine down? Cheers |
4th Feb, 2007 at 04:31:13pm
if you crack the box off ,you'll disturb the paper gaskets between the block and box, so you will need to strip down, |
4th Feb, 2007 at 06:13:29pm
as carl says engine out and strip down iam afraid
4th Feb, 2007 at 07:03:15pm
i use wellseal on this one on both sides. doesnt seem to leak then.
4th Feb, 2007 at 07:10:44pm
Done one in car before(with flip front)took rad,timing gear and backing plate off,undone engine to block bolts split engine just enough to get it in.
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
5th Feb, 2007 at 08:54:14pm
Glad someone else is also wanting to know this, as i usually have probs with this, can never get this to seal! which way does this go round, do you any sealn't, or dry?
5th Feb, 2007 at 10:17:52pm
Yup, use wellseal ^^^ |
