| Home > Help Needed / General Tech Chat > Hole cutting... | |||||||
8th Feb, 2007 at 04:45:25pm
My new bonnet has arrived and I want to cut some holes in it again for my intercooler!
8th Feb, 2007 at 04:56:02pm
You mean a Q max cutter, these are very good but as you say theres a curve. A holesaw is your only choice. Youll just have to file it up afterwards.
I seriously doubt it! |
8th Feb, 2007 at 05:14:06pm
you could try an angle grinder, or plasma cutter but the hole saw will be neat ish compared |
8th Feb, 2007 at 05:18:52pm
A good quality hole saw is best, the solid metal ones, not the spring steel type ones.
8th Feb, 2007 at 05:44:43pm
i've had good success with stepped drill's, but that was on flat stuff... On 28th Aug, 2011 Kean said:
8th Feb, 2007 at 06:10:22pm
as in these:
8th Feb, 2007 at 06:15:30pm
Yea thats what was used last time. The bonnet was shagged anyway so I was to bothered about finish!
8th Feb, 2007 at 06:41:04pm
If you drill a pilot hole, and use a hole cutter ( like above ) with a soild bar for a pilot, they work a little better.
8th Feb, 2007 at 09:12:14pm
Place the bonnet on a piece of wood, if you can get one that has a similar radius to the bonnet so much the better.
8th Feb, 2007 at 09:43:27pm
Stepper drills do give a neater cut. Not sure how big you can get them tohugh, the biggest I have is 32mm Fastest 998 mini in the world? 13.05 1/4 mile 106mph
9th Feb, 2007 at 01:09:05pm
I use one of above, but mine is yellow!, so much better On 15th May, 2009 TurboDave said:
9th Feb, 2007 at 01:19:23pm
I got my step drills from work (read 5 finger discount On 28th Aug, 2011 Kean said:
