Home > Help Needed / General Tech Chat > Crownwheel bolts
Turbo Tel
Member #: 588
Delaware, USA
Got my sexy crosspin diff today. Minispares seem to have a few now.
Did I see somewhere that you should replace the crownwheel bolts?? If so I forgot to order them, anyone know the tensile strength maybe I can get some locally.
Mine look fine, do many of you guys reuse them?
Terry
Edited by Turbo Tel on 9th Feb, 2007.
I always use the stock bolts personally.
Yep me too, never had a problem with them.
Turbo Tel
Member #: 588
Delaware, USA
I didn't explain myself well. What I meant was-
Should I re-use the stock bolts or always buy a new set when re-assembling the diff?
Terry
turbo hogster
Member #: 178
stowmaket suffolk
no use the ones you have, they will be ok
Turbo Tel
Member #: 588
Delaware, USA
OK thanks
They look pricy anyway and with the tabs they're not going anywhere..
Terry
might be making this up, but arent they the same as the turbo dive flange bolts?
probably a myth...?
