| Home > Beginners Tech > diff help | |||||||
173 Posts Member #: 873 Advanced Member Thatcham, berkshire |
9th Feb, 2007 at 09:02:45am
i cannot afford to go mad with the gearbox at mo so i will be using the standard box as i wont be pushing to much horses out yet but i did read that you should change the diff to a 4 pin diff. i8s this the best one, what ratio diff should i go down too. do you need to ask what ratio you want or do you fit your crownwheel into the diff. is that how it works, as i was reading topics and everyone says get uprated fiff, but then i read loads other pages and people asking for different ratio diffs. im just trying to learn this stuff myself. my dads the mechanic but i wanna no this stuff too ill be able to shock him. ive picked upp all the other bits really well.
9th Feb, 2007 at 09:23:14am
ok i think i have sussed it out i was bein a flid, the crownwheel is where you get the ratio bit from, and the 4 pin diff basically a sepereate bit to the vrownwheel, it fits on next the it.
9th Feb, 2007 at 10:10:05am
Count the teeth on the gears and divive the little number (pinion teeth number)into the big number (crown wheel teeth).
9th Feb, 2007 at 01:56:38pm
yea cheers dude. i might just stick with the the one outta tyurbo box they are 3.2 i believe arnt they.
