Home > General Chat > Vizzard
shane
Member #: 1246
Lowestoft, Suffolk.
There a couple of versions of the vizzard book in publication (white paperback, yellow hard back, and a blue version, to my knowledge), which is more helpfull?
Thanks
Shane.
You want the 3rd edition of tuning BL's A series ideally, it just has a bit extra in it and if you buing you may as well jet the one with more in.
Beware if your ebaying though the 2nd and 3rd editions look similar at first glance
3rd edition...
http://www.amazon.co.uk/Tuning-Engine-Defi...ie=UTF8&s=books
2nd edition
http://cgi.ebay.co.uk/Tuning-BLS-A-Series-...1QQcmdZViewItem
1st edition...
http://cgi.ebay.co.uk/DAVID-VIZARD-BL-A-SE...1QQcmdZViewItem
also the how to mod your mini is an ok read if it comes up cheap, but TBH its a bit dated now.Does cover the whole care rather than just the engine though.
http://cgi.ebay.co.uk/Modify-your-Mini-by-...1QQcmdZViewItem.
shane
Member #: 1246
Lowestoft, Suffolk.
Thanks mini13, thats the sort of answer I was hoping for!!! Already have " how to modify your mini" was after a lot more info so was after a copy.
Thanks for your help.
Shane.
no worries, I included how to modify your min as i've never seen TBASE in paper back so thought you might mean that.
also the Des hamill book is quite good, IIRC it hase some stuff on engine clearances which is usefull.
shane
Member #: 1246
Lowestoft, Suffolk.
The Des Hamill book, is that one of the speed pro series, think I have one of those for the 998cc, any idea if the 1275 version is any different?
Shane.
yep thats the one, I havent seen te 998 one but from the look of the 1275 one they would be a bit different, especialy regarding heads.
shane
Member #: 1246
Lowestoft, Suffolk.
the 998 one made for good reading, am curious to have a look thru the 1275 one tho.
Shane.
I thought i noticed some information had been editited out and 'some' new information edited in, between the 2nd and 3rd editions???????
I couldn't find any/ didn't notice any that had been taken out but i did wonder about that too.
Don't forget this books are great as a guide, but things have moved on a lot since then so they are not the only way of doing things.
turbo hogster
Member #: 178
stowmaket suffolk
and some of the info is a bit sceptiacl to say the least. especially on turbo's
shane
Member #: 1246
Lowestoft, Suffolk.
It was the turbo side of things I was looking for, so now thinking about it I may not bother.
Shane.
Des Hammil's books are shite. Stay away!!
