| Home > Technical Chat > salisbury diffs and late model casings | |||||||
11th Feb, 2007 at 05:03:05pm
well ive just got around to looking at a gearbox i have,
Edited by fastcarl on 11th Feb, 2007. |
11th Feb, 2007 at 05:15:12pm
Ive got a Salisbury, Yes you need to take shit loads out of the g/box case and the diff cover. You do come very close to going through. I helped mine a bit by fitting high grade button head bolts to the crownwheel. Careful shimming is a must on both sides of the diff, no just one side as per the norm. Do be careful as the crownwheel could touch the mainshaft bearing.
I seriously doubt it! |
![]() 399 Posts Member #: 793 Senior Member Milton Keynes |
12th Feb, 2007 at 07:02:52pm
I agree with Paul totally,
1425 Posts Member #: 690 Post Whore Norfolk |
12th Feb, 2007 at 07:20:37pm
nice to see you back on her Gav!
If Carling made Mini engines
13th Feb, 2007 at 05:45:55pm
On 12th of Feb, 2007 at 07:02pm Gavin Wakely said:
I agree with Paul totally, I've just put on into a turbo box and had alot of the afor mentioned problems. Carefull measureing / grinding of case / shimming on both sides was necassery, aswell as reducing head hieght to 4 mm on the 8 bolts, wich hold the Salisbury together. I'm sure it has already been done but the Salisbury itself does require machining to fit into any mini box (Large chamfer on the non crownwheel side) all the above is becoming more apparent day by the day,lol i just reread your post Gav, and is machining the diff a good idea, its not been done up to now, i see what your suggesting, gut never having had one in bits i don't know how thick the diff housing is around said area, i'll assume its thick , and that youv'e had no problems,it does seen like a ray of ligth i must say, i was looking at build up weld to the outside of the diff housing around the offending area just in case i had to really had to rem ove lots, , but the diff maching sounds like it may make thing a bit easier, carl Edited by fastcarl on 13th Feb, 2007. |
![]() 2641 Posts Member #: 19 Post Whore newcastle |
13th Feb, 2007 at 06:05:48pm
die grind away carl .... you need to take ucking loads off Everyone knows that instructions only have to be read if the thing doesn't work....
