Home > Help Needed / General Tech Chat > what parts do i need on my a+ for a pre-verto clutch setup???
clubminiflip
Member #: 54
nr coventry
a list would be gr8 as i'll be putting a wanted out i think!
& what clutch recommendation would you make for my 998 turbo motor
many thanks chaps
shane
Member #: 1246
Lowestoft, Suffolk.
You would need,
Pre verto slave cylinder
to fit the wok with the longer lever arm asy as pre verto
pre verto backplate/fly wheel
also ensure you have the correct ring gear for your starter type, either pre engaged or inertia.
what hp are you looking for, would think either orange or grey diapram with minispares rally friction plate for power around the 125 bench mark
think thats it, correct me if Im wrong gents?
Shane.
clubminiflip
Member #: 54
nr coventry
SO I ONLY NEED THE WOK END PIECE OF THE CLUTCH HOUSING, THE OTHER CLUTCH HOUSING PART I CAN KEEP, THE INNER PART
& CORRECT FLYWHEEL, PRE-ENGUAGED OR INERTIA, MY CAR IS A 86 WITH THE SOLONIOD ON THE STARTER
I THINK AT THE MOST I'D BE LOOKING AT 140 LATER ON DOWN THE LINE BUT AT PRESENT I THINK 125 IS SOMETHING TO AIM FOR
clubminiflip
Member #: 54
nr coventry
sorry bout the caps
shane
Member #: 1246
Lowestoft, Suffolk.
The transfere casing you can keep, also the wok can be retained you just need the plunger and lever arm for pre verto.
It sounds like you have pre ingaged starter, which means you will require a pre verto flywheel with the starter ring gear for inertia starter.
If the plan is for big bananas in the long term plan i would fit a grey cover as i think its only a few £ more, hope this helps
Shane.
Disk full (/tmp/#sql_15dff7_0.MAI); waiting for someone to free some space... (errno: 28 "No space left on device")
