| Home > Help Needed / General Tech Chat > Inlet manifold | |||||||
36 Posts Member #: 84 Member |
12th May, 2004 at 02:33:25pm
I've done a search and apparently i can use a NA manifold with the mirage kit, but can i use a turbo manifold? |
12th May, 2004 at 07:29:53pm
i'd have thought it would be really difficult to get at the manifold nuts using the NA inlet, its way easier to take off the turbo manifolds than the NA ones imo On 20th Oct, 2015 Tom Fenton said:
12th May, 2004 at 07:41:14pm
The flanges on the Turbo inlet are thicker than the normal MG inlet. The Mirage kit is designed for the normal MG, so the flanges on the exhaust are of the same thickness. I guess you could use some stepped washers & use a Turbo manifold with the Mirage kit.
Edited by Turbo Phil on 12th May, 2004. |
