| Home > Help Needed / General Tech Chat > COULD THIS BE DONE RELATIVELY EASILY ?? | |||||||
3 Posts Member #: 269 Junior Member |
12th May, 2004 at 06:26:15pm
Sorry 4 caps locks. Would it be expensive to fit an rsturbo engine into a mini ?? or any other small powerfull engine ??, what would you be able to put into a mini with most power and least hassle ??? thanks very much 4 any/all help i recieve. |
![]() 164 Posts Member #: 206 Advanced Member Milton Keynes |
12th May, 2004 at 06:45:43pm
HOw wide is the engine and box ? 9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked |
12th May, 2004 at 06:52:54pm
i would say unless you were an expert welder and engineer it would be pretty expensive to do it. i would probably say the least hassle approch would be an a series of some description. maybe vtec or vauxhall converstion could be an idea
12th May, 2004 at 07:27:23pm
if your going for a different engine then i'd personally go for a VTEC conversion, then you can bolt a turbo onto that pretty much. not sure how much room there'd be mind, but probably easier than an RS turbo install as the stuff is tried and tested for the VTEC conversion. On 20th Oct, 2015 Tom Fenton said:
12th May, 2004 at 07:47:59pm
VTEC conversions seem to be getting more and more popular, as do the Vauxhalls. Both will give good power with reliability.....
244 Posts Member #: 34 Senior Member |
12th May, 2004 at 10:30:04pm
RST has been done before, but the engine was in the back as I recall.
