Home > General Chat > where can i check a part number chaps?
clubminiflip
Member #: 54
nr coventry
where can i check a part number chaps? its for my crank
What is the number?
Paul
clubminiflip
Member #: 54
nr coventry
it is 12A1451R
IS IT A OR A+ OR DOES'NT IT MATTER?
Edited by clubminiflip on 14th Feb, 2007.
Thatll be a pre A+
Paul
clubminiflip
Member #: 54
nr coventry
can that be used on an a + block & rods, i have been told the part number is the same be it a o a+
miniminor63
Member #: 672
The oversills police
Oslo, Norway
no problem to use that.
clubminiflip
Member #: 54
nr coventry
it will be ok then??? there is'nt any differance's between the a & a+ type, sorry i am having a stress :)
my block & rods are a+ and my crank is a 12A1451R
Both my 998 A+ cranks have that number.
clubminiflip
Member #: 54
nr coventry
RIGHT CHAPS, BIG BIG BIG THANK YOU'S, YOU'VE CLEARED SOMETHING UP FOR ME,
CHEERS AXEL!!!
I KNOW I HAVE LOADS OF QUESTIONS BUT I AM A BIT NEW TO DOING MY ENGINE BUT I'M SUPER CONFIDENT IN MY AIMS & WHAT I NEED NOW & YOU ALL HELP ALOT! I FEEL THERE IS MORE REAL EXPERIANCE ON THIS FORUM THAN ANY OTHER ALTHOUGH I DONT REALLY ASK QUESTIONS ON ANY OTHER AS I'VE FPUND IT POINTLESS
YOU LOT ARE A REAL HELP & I'M LEARNING LOADS ON THE ENGINE & BOX/IGNITION/FUELING,
ITS ALL WELL & GOOD READING & HAVING A BASH BUT A KNOWLEDGABLE BUNCH LIKE YOURSELVES TO CONFIRM LIL QUESTIONS IS GR8, JUST WANTED YU ALL TO KNOW
I'VE FELL ON MY FEET WITH MY GEARBOX TOO & WANT TO LEARN TO BUILD THAT & AN ASSOSIATE IS A MINI GEARBOX SPECIALIST & HAS SAID IF I GET MY PARTS HE'LL GO THROUGH HOW TO CHECK/DECIDE & PIC PARTS TO REPLACE TO RECONDITION MY OWN BOX SO I'M QUITE CHUFFED WITH THAT OUTCOME
HOPEFULLY I'LL GET THIS ENGINE RUNNING IN A RELIABLE MANNER :)
CHEERS
