| Home > Help Needed / General Tech Chat > dump valve | |||||||
164 Posts Member #: 1271 Advanced Member Berkshire |
17th Feb, 2007 at 03:20:16am
whats the difference in a recirculation and a non-recirculation(?) |
17th Feb, 2007 at 04:00:21am
A non-recirculating d.v. vets the boost pressure to atmosphere with the "ptsccchhhh!" noise.
784 Posts Member #: 912 Post Whore North Yorkshire |
17th Feb, 2007 at 04:51:26am
Just a question?
I drill holes in everything..! |
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
17th Feb, 2007 at 08:30:53am
don't think it makes that much difference on a series tbh, would be interested to see if anyones tried though.
17th Feb, 2007 at 03:24:15pm
arent the recirculating ones there so that the airflow meter doesnt get all mucking fuddled?? |
17th Feb, 2007 at 06:12:43pm
I think it more for the quietness, you can get a twin piston non-circulating one that works with airflow meters. On 7th Nov, 2008 Nic said:
274 Posts Member #: 1174 Senior Member Sunny Southern California, USA |
18th Feb, 2007 at 08:55:32am
On 17th of Feb, 2007 at 03:24pm Nic said:
arent the recirculating ones there so that the airflow meter doesnt get all mucking fuddled?? It is. If you just dump to atmosphere, the car will run rich because not all of the air it has metered will make it into the cylinders. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
18th Feb, 2007 at 10:30:28am
arent the recirculating ones there so that the airflow meter doesnt get all mucking fuddled?? It is. If you just dump to atmosphere, the car will run rich because not all of the air it has metered will make it into the cylinders. just a thought tho, the only time the d.v will be open is with the throttle closed, so it wont be fueling at all? (on an injection car anyways?) open to criticism, but just my idea:) |
19th Feb, 2007 at 05:54:45am
On 18th of Feb, 2007 at 10:30am pot_dan said:
just a thought tho, the only time the d.v will be open is with the throttle closed, so it wont be fueling at all? (on an injection car anyways?) open to criticism, but just my idea:) If it wasn't fueling at all when the throttle was closed, the engine would shut off every time you let off the throttle. You are always getting enough fuel to at least idle the motor. 61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
