Home > Help Needed / General Tech Chat > megajolt map connector
steve1275
Member #: 951
Bromsgrove
Anyone tell me where to get a bulkhead connector for the MJLJ casing to fit the map sensor pipe?It's a tiny little b*****d and none of the usual stuff seems to fit.Thanks.
'Where does the engine go?'
I got a load from a model shop, designed to be used on fuel tanks for RC Cars & Planes. PM me your address and I'll pop one in the post.
i ran my pipe through a grommet
oh hang on, di you mean into the unit? or through the engine bay bulkhead?
Edited by Nic on 17th Feb, 2007.
steve1275
Member #: 951
Bromsgrove
Yes it's into the unit.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
tie a knot in the pipe and feed it through to the outside of the ECU.
Or struggle to find a plastic/brass barb :)
either works fine....
just avoid leaving a pipe hanging on the sensor pulling it off the PCB.
alex
AlexF
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
As rob said ....... in every model shop that sells IC engined planes!!!!
steve1275
Member #: 951
Bromsgrove
Thanks for that.The power of Turbominis!
RogerM
Member #: 1217
I just noticed where you are.
I probably should say try DC Racing in Evesham as Dom is along standing friend and sponsor. I am fairly sure however that he'l have to get them in as he is a model racing specialist (some would say THE model racing specialist) and thus doesn;t stock planes etc.
Near you could try CDS models (just outside the Aston Fields Ind Est) failing that 1st models.
steve1275
Member #: 951
Bromsgrove
Thanks Roger,got one from CDS yesterday!
A bit late now but I've finally found mine, only took six weeks of searching the workshop. Do you still need one?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Merlin motorsport do them http://www.merlinmotorsport.co.uk/advanced...ywords=bulkhead
steve1275
Member #: 951
Bromsgrove
Thanks Rob,got one from the local model shop.
Alex1340
Member #: 111
Loughborough
I need one now any one got a spare?
Thanks
Richie
Member #: 628
is this a nipple type thing for a tube ? i have lots and lots of model shite ie planes, cr, and tonnes n tonnes of shagged engines, may be able to butcher them in the name of TM ?
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
I'f you PM me your details I'll post one out to you.
Thanks
t3gav
Member #: 229
Gavin@minispares.com
kent
Hello, old post i know but i dont suppose anyone has a spares lying around and the pipe too would be good, cheers
I've got a few left, I've got to convert a MJ from TPS to MAP for Phil in the next couple of days so I'll dig out a connector for you when I'm at it.
t3gav
Member #: 229
kent
Nice one cheers, pm sent
