Home > Help Needed / General Tech Chat > conector mpi tank
QuimFintas
Member #: 1021
Portugal
where can I buy a connector to wire a mpi tank?
Daniel
If its the same as an SPi tank connector, large white thing with two terminal at right angles, then two 6mm spade terminals will do the job.
Otherwise the scrapyard may be your best bet as it will be common to some other Rovers.
