Home > Help Needed / General Tech Chat > A Thougt About Fuel Pipes
I'm in the process of sticking a T2 on my daily 998 hack. One of the jobs is the fuel pipes.
Now I run 8mm feed and return on the TT and this works fine. However on the road 998 I'm only planning on running 8(ish)psi with around 90 bhp.
I don't have much time (or money) for this conversion so I was thinking of using the standard fuel pipe as a feed. Considering that it comes out of the tank and goes into the carb at the same diameter as the standard pipe, I don't see a problem.
What are peoples thoughts?
danboy
Member #: 1381
The hole in the needle valve is only 2mm (approx) and all the fuel for the engine has to pass through this.
So standard pipes should be fine.
Regards
Dave
Turbo Shed
Member #: 30
Epsom, Surrey
the needle valve may only be 2mm, and i use the standard pipe out the tank BUT the length of the restriction affects the fluid flow as well as the size of the restriction.
to be fair it should work fine.
you can even cheat further and not fit a fuel return. fit the fuel pump under the bonnet and fit the return from the regulator into the back of the pump with a "T" peice. it does work and works fine. also you can use a standard tank
Ric
Member #: 36
Basingstoke
that's bloody clever! i like that a lot.
Turbo Shed
Member #: 30
Epsom, Surrey
it works fine BUT i would and have done the job properly. my reasoning is that fuel may vapourise (spelling?) and then the vapour is pumped round and round not back to the tank
andeh
Member #: 97
Near Daventry, midlands
not all pumps can be 2m away from the tank or can self prime either
Ive seen 8mm OD hardline pipes feeding in excess of 500bhp in efi trim on different cars, with some having several 90 deg bends.
I wouldnt have too many concerns about even a 6mm OD feed pipe to a carb/reg on a Mini lacking in flow, especially with an efi pump
